Connecting a Roland Soljet Pro II to my PC
jfk252
I have recently purchased a second hand Roland SolJet Pro II and am trying to connect it through an IP connection, i know you type in 'cmd' and then 'ipconfig', but then I get a bit baffled with Ip numbers etc. does anyone have any experience with this?
Devon19515
What rip software are you using? Our set up is thru Flexi production manager, add setup, then it goes step by step.
jfk252
Modern Ethernet switches and ports do not need a cross-over cable. If you are dealing with an older switch (or Ethernet port), that may be necessary.
Thanks, got it sorted! Contacted local technician, going into network adapters, and changing IP4 numbers to match printer.
