Connecting VPI Versacamm 540 to a new router
Wbgofd
Good Morning,
I replaced my router and everything connected EXCEPT my versacamm printer. I am using versaworks. The printer was connected and working great until the router was changed. The router is a TP Link and is connected to the printer with a cable. Any help or ideas would be greatly appreciated.
Thank You!
Larry
FrankW
Most of the time this issue happens when new routers DHCP-Servers distributes IP-Adresses of a different subnet, while the printer is on a static IP.
Example:
Router gives the RIP-Computer dynamicly 192.168.10.50, the printers static IP-Adress is 192.168.10.60, this will work.
New Router gives the RIP-Computer dynamicly 192.168.50.50, the printers static IP-Adress remains 192.168.10.60, this will not work (192.168.50.60 would work).
Check your PC´s IP-adress, set the printer to an adress of the same subnet (first three digits the same, last digit different), which is not used with any other device in your network.
  • Agree
Reactions: 1 user
