knucklehead
Got some Knomad ChalkArt images I want to print, and contour cut in Corel X4.
They are psd files. I've messed around with making a contour cut line with the bezier tool on a couple. Still need to work on the layers part.
Then, I have noticed, if I go to 'edit bitmap' function, and then it takes it into PhotoPaint, it will be on the checker board background, with a blue dashed line running around the outside contour.
This is exactly what I want to cut, is there anyway to make this blue outline, into a contour cut line? Thanks
