Contour cut with CE5000
juan45215
I justbought the CE5000. I'm having trouble setting up the contour cut. It reads the first reg mark, but it only reads the second mark if it is within about 8" of the first mark.
Any suggestions will be appreciated.
Jackpine. Are out there?
gvgraphics
The answer will depend on what flexi you are running. For 7.6 Click Here and if you are running 8 Click Here.
You would follow the directions for the CE3000Mk2 cutter as it is the same as the CE5000 cutter.
Hope this helps. If not specify your exact issue and I will help you resolve it. If you want to PM me your # and I will call and help you.
JackPine is probably still in bed............Had him up late setting up Flexi on his system!
juan45215
Never mind. I found the problem. The printed image is larger than actual size for some reason. When I send it to the cutter it cuts the correct size. Now I have to figure this out.
