Need Help Contour cutting
hankweezie
I have an older printer a soljet ll 540
It just stopped contour cutting and just cuts straight across when printing is done, any ideas where my problem is?
I would check your settings to make sure you have print & cut still selected. Also I always print the crop marks incase it does something like that so I can load the material back into the machine and have it find the crop marks to cut after.
hankweezie
I tried a graphic that would contour cut but it did not cut like others.
Tried several none would cut, I thought maybe a setting is off
