Gene@mpls
Ok- we work with contours a lot and I find the contours somewhat
awkward to work with in 7.6. I my old reliable v5.7 you can select the
contour color by turning the other colors off- in 7.6 I have not found a
way to reliably select the contours. I sometimes have to open the resulting
eps in my wasatch rip to tell if the contour is correct. You can have a contour
on the same line as a graphic component and not see it. Am I missing
something here? Thanks Gene
. Thanks Gene
