Corel X6 PDF settings
Does anyone here output from Corel X6 for Print and contour cut using PDF using RGB color mode?
This is a strange thing that just started happening in the last week but my PDF settings kept going back to Default settings. I hadn't had to mess with the settings for so long that I can't remember what all I had checked marked.
The problem is, now if I output using PDF with a contour cut it prints just fine but the contour cut is a 1/4" off. If I output using EPS the contour cut is dead on which tells me it's not my cutter it's the output method.
I always used PDF - RGB because the color output was so much better than EPS.
If any of you Corel users doing print/cut could give me some direction on the PDF settings it would be great.
Thanks in advance.
