Cotek cutter plotter driver
seliparsurau
Hello I'm newbie here, I have a simple question. My cutter plotter have a two alternative port connection, usb-b and rs232 serial. Unfortunately usb-b port has damaged. So I would like to buy a rs232 cable to use it. Does it require a new driver for rs232 or just use already driver I have installed for usb-b?
timgo
Graphics Designer
You have nothing to do. Your indtalled RIP software support your plotter,
Yolandi
i need a driver for my cotek ctk-720 cutting plotter.
Trying to connect through usb but now in Corel draw it doesn't pick it up
timgo
Graphics Designer
No new driver needed!
Only change the setting of your cut software to the USB port to Com port.
Only change the setting of your cut software from USB port to Com port.
Yolandi
I have done that but it is not cutting.
If i press test it works but when i press print or cut/ plot nothing comes out. Or it runs and then my pc just restarts or it does a crash dump.
timgo
Graphics Designer
If not, mybe all ports/mainboard has damaged.,
timgo
Graphics Designer
I can see the PORT wich rhe printer is in and is says device working properly.
And whybwill it do a test print from the computer.
What is your software for "cotek ctk-720 cutting plotte"?. The software must be support the driver of your cutter. Install the software again.
Yolandi
Now before downloading this driver it starts to print a letter but then syops and just cuts a straight line through yhe whole page width.
jumaduvi
hello, i hope someone will be able to help me. i have never used a plotter before. my dad bought a used cotek (ctk870c). we don't have a driver for it though. i've been looking all over the internet but i just can't find it. does anyone know which driver i need for it to work?
Yolandi
Windows 10 did an update now my cotek ctk 720c cutting plotter now longer wants to work.
I get a message error initializing cutter.
I have connected it with a Rcs232 cable an still no luck .
were can i get a driver of can someone help.
working on windows 10 64 bit and signblazer elements
