could I get a check on price?
Kysparky
$' x 4' exterior signage x2. Materials to be exterior grade plywood primed and painted with a latex acrilic paint. vinyl will 12" on for sale, 5" on prime etc, and 10" on number. One price I have is $290.00 delivered and the other is $375.00 installed on 2 4x4 post. Am I off base? giving it away?, or somewhere in the ballpark??????? sure would appriciate the input.
Remember it isn't fancy just readable
:thankyou:
rcook99
I am currently doing on very similar but the size is 4x8 installed one color text for $450.00 plus tax. So I would stay on the high end of your price
flisk
If this helps, we are doing a 4'x8' MDO 1/2" thick single sided, with a digital print applied onto it. It will have two 4"x4" posts to mount it on, they will be painted white. Uninstalled the sign is $492.00 Installation is $112.00.
It's going to take 2 people to apply the digital print, and 2 people to take it to the site and install it, we will use an auger to dig the holes (and post hole diggers to help with the excess dirt).
The site is about 20 minutes away from the shop.
flisk
we use a roller to install it, it still takes 2 people to handle a heavy 4'x8' 1/2" thick piece of MDO (one person handles that while the other handles the actual print as we feed it through the roller).
Kysparky
I try to use the signwriters guide but those prices are so high for this area.. I usually have to knock off at least 40 and sometimes 50% Gotta watch that book
Gary Welch
Cody,
I am wondering what you pay for the MDO. We buy prepainted MDO for about $80 sheet, plus vinyl, overhead on equipment and building. We would be about $400 for this sign. Have you checked to see what other people in your area charge?
Gary Welch
High Performance Signs
Ken
First thing..I Hate digging holes,,so I avoid that like the plague.
I no longer use MDO, plywood. I preferr Econolite, Alumalite, Prolite..whatever you call it. Aluminum on both sides with a corrugated plastic core. This avoids the need for prime /sand/paint/sand/paint.
Very time consuming to do this. If you use the composite material..it is MUCH easier. Price will be almost the same to the end user but you will have a much more durable sign.( and less work/time for you)
I'm not quoting numbers as you requested, but I encourage you to consider this method.
Cheers!
Ken
Columbia Signs
We make pretty good money at $199.25 for a 4'x4' sign with simple text..... over 50 points. Since you asked, we're in the mid 30's per sheet (that's 2 sided good ½" MDO with the backed primed). However, we do buy several hundred a month to get that price. We truck it in several units at a time.
Also, we have 3 full time installers digging 20 to 25 holes each day for signs, so we can keep the price of installs down too.
We do A LOT of MDO signs. If our customer buys 50 signs for example, we can get them painted, silked screened, and simple vinyl lettering for well under $100 a 4'x8' sign. Even less if the buy more.
This market is our bread & butter.
Cody,
Gary Welch
Kysparky
Thanks for the input here folks. I may have to do a little revision but seems like I am at least inside the park. Thanks This forum really helps to get some understanding of what you are doing. All signs are different as well as the customers.
I think cody @ columbia signs is @ about the right price he is saying what he would charge $199.00 for 1 4x4 1/2" single face. I see you guys were quoteing for just about double that on 4x8 1/2" s/f, however what kysparky was asking for is he within the ball park for 2 4x4 signs, I would say about $250.00ea for the faces, $25.00 ea. for the posts, and $75 installation. for a total of $625.00 + tax
