Countour vectors
bpfohler
Just got a copy of Print and Cut light with our new HP latex.
When I open vector files I try to add a countour cut. Sometimes it works and sometimes it select an interior shape and attempts to add a countour to the interior shape.
Is there any way to select just the exterior shape and add a countour ?
AKwrapguy
What do you mean by Print and Cut? Are you talking about Flexi?
bpfohler
Ya, sorry I didn’t specify but that’s why I posted in the Flexi forum. Is there any way to select just the outside vector in Flexi and apply a contour cut? Is it easier to convert images to rasters and add a contour?
bob
Yes. No.
joeyhalderman
Can you post a screenshot of the file you’re working on? I can explain the best way to contour but it would help to see the artwork.
Drip Dry
Sure, when I get back to the shop I’ll take a screen shot.
When your creating a contour, there is a checkbox that says " with holes".
Uncheck the box and you will only get the outside contour
Also, make sure your using the contour cut option from the effects menu
AKwrapguy
I would never convert to raster unless I would really need to. example if there was an issue with transparent gradients or something in the original artwork that wasn't coming through properly.
With out seeing the file it's hard to say what the issues is. It could a mask issue or a group issue, it could also be a simple issue of having the 'with holes' checked or un-checked.
2ny
In Flexi, when you have selected your object, you can right-click on the object and choose "Select within" from the sub-menu. Then click on the single object you want to select within any group or combined object to select this.Otherwise you need to break your object apart, and then work on the single outline.
Best regards
2ny
Select your entire image you want to contour cut. Group that together. This is key. Sometimes If you leave them ungrouped it will create a contour cut around every object. if you group everything it treats it as a single object.
