SightLine
I've been asked about this before so I thought I'd share with the premium members here. While I'd always prefer to either hand lay and turn real gold leaf or use Real Gold http://www.realgoldinc.com/ sometimes its just not in the budget for a customer for a certain job. There are just not many very good engine turn pattern files around for printing simulated engine turn so I had set out some year back to create my own and it was quite easy. Now I did go with a pattern that more simulates the Real Gold and other pre-made vinyl engine turn patterns meaning the rings are more pronounced versus the softer look of real hand turned gold. I created the pattern quick and easy using the Alien Skin plugin for Photoshop. I'm sure it could also be creates as pure vector in Illustrator but this is how I did it. I'm sure this can also be done in some way with Corel software but I don't use that so I cannot help with that.
Attached and below is a 300 dpi transparent png of the pattern itself. Its 1" in diameter and you can crop it down easily to a smaller size like 3/4" or even smaller if you want. I've never needed a pattern larger so I've never bothered to make one any bigger.
So this is just a single circle. Not terribly useful as it is. Now I just open this in Illustrator (I'm using CS6 so in other versions some things might be a little different). Once you have the image open then select it and from the Object menu select Pattern>Make. It will tell you it has added it to the swatch library then you should see the Pattern tool pallet. On the Pattern tool pallet then you want to change a few things but feel free to play with the settings. For the standard look that I want I use the following.
Tile Type - Hex by Row
Size Tile To Art - checked
Move Tile With Art - checked
H and V Spacing (linked) - both as (negative) -0.125
Overlap - Right in Front and Bottom in Front
Copies - 9x9 (but you can change this to whatever you want but it needs to be more than 1)
Then give it a useful name and click done in the upper left of the window. Now its a color choice in your Swatches pallet. With it there you can then select any shape in Illustrator and use the new pattern as a fill and it will do so seamlessly even if the shape you are filling is larger than the pattern you creates was.
You can also take the original single transparent png image and adjust it in Photoshop if you want to alter the color, change it to CMYK (yucky dull lifeless mode), save it as a transparent tiff or native Photoshop PSD, or other file format, etc. If you save it as a native Photoshop PSD you can also directly use it in the same manner In FlexiSign. In Flexi though you would use the "Step and Repeat" tool to make the overall pattern as big as you need it. Then select the shape(s) you want to fill with it, put them on top (if more than one shape compound them first), then select the shape(s) and the pattern you created and mask it.
Hope some of you find this useful. These same methods are also useful for creating any pattern fills really. I've found that many folks have never really used the pattern tool in Illustrator before and are surprised at how simple it really is.
