CRM - Customer Relation Management Software - W/ Signvox
Spencer McMurtry
Hello,
I just recently started being a lot more aggressive with doing sales / going after larger clients, I have 6+ prospects in progress right now and its getting a bit confusing tracking it all...
I know there are a ton of different options for CRM software, I am looking for some suggestions. I currently use signVOX so if it could work with that this would be ideal.
Thanks!
Spencer
Kevin-shopVOX
Hello,
Thanks!
Spencer
Hey Spencer. You can definitely do this with signVOX. I called and left you a message to walk you through it so if needed give me a call back. I will attempt to explain it here.
The CRM aspect of signVOX starts with sales leads. Essentially you create a sales lead which allows you start tracking the conversation from the first interaction with the customer. Categorize your notes based on the type of interaction with them and assign tasks to yourself or employees for future action. As the conversation progresses move the lead into a variety of stages the lead could fit such as preparing quote, lost, assigned etc. Additionally as you are ready to quote, add a quote directly from the lead. The system keeps track of the age of the lead as well as automates visual color changes as the lead ages.
Once the quote is created all of your sales notes will be on the quote itself where you can further add notes based on interaction with that customer again. Furthermore, sV will alert you that your quotes need attention if you ignore them after created. If you do not comment or move the quote to another transaction state your MyVOX tab will show how many quotes require attention. Click the link and see all quotes with notes, last contact date etc.
Lastly, use the sales routes tool to see who are leads, prospects, closable and sold. As an example. Say you have to go on site to do an install. You can pull up the customer and every customer is linked to a google map. Click the show neighbors link and you will be able to filter your customers by status, industry and sales rep and if they are near your install customer they will show up as well as a proximity route for you to use.
Again give me a call and I can go over this in detail a little more but I hope this helps.
Spencer McMurtry
Thanks for the advice / Call Kevin, I am current using this lead system. It is working great, i will keep you posted on any additional questions!
