Cut is our of registration???
SCOTTD
I am having an issue with a print cut file.
I can print lam & cut cutter finds image and cuts correct.
If I do just a print cut it cuts out of registartion .
Anybody had this happen before?
Roland tech says encoder strip has gone bad??
Thanks Scott
SCOTTD
Cutline Issue Fixed!!!
The linear encoder strip had dust on it wiped it with a cotton glove and it works fine!!
Just take your thumb and index finger and gently wipe down both sides from right to left and you will be supprirsed at the amount of dust in there!!
