ProdPrintMan
using Onyx 25 to create the print file for HP R1000 and cut file for our Multicam Apex 3R (being run by enRoute).
I have it set up to print the small Onyx barcode in addition to the route registration dots. this setup has been working until I try to add the small job ticket label. this is moving the route line an arbitrary amount. Anybody have this issue and have a fix? I have tried different cutter X/Y Margin amounts but it looks to me like Onyx prints the label fine, but doesn't take into account that extra print area properly, so the reg dots are in the og location (as if there was no label), while the cut file moves the cut shape to account for the addition of the label.
I also saw there is an update to Onyx 25.5, wondering if anyone has had this issue and updated to 25.5 and it went away?
Other thoughts:
- wondering if I could add .25" to the top of the artboard when I save the pdf from Illustrator, then when I add the label, make it at it to on top of the art instead of above?
- any of the X/Y settings that I am not getting right that could make this work?
- one of the other settings for pdf job files page size (like turn on "Only use bounding box"), or use media box, art box, etc?
thanks. having the label print would be helpful with our process, to include the file name, date and time, and job number right on the edge of the print.
Other thoughts:
