Cutting along gaps on painted roll-up doors.
We're cutting and installing new number decals for a local fire department, as the equipment numbering requirements have recently changed. We're making one of these roughly 34" x 13" numbers to replace the one pictured using Oracal 383 Ultraleaf over Oracal 751 gloss black. Does anyone have any advice on the cleanest way to cut along the gaps? Are there any magical new wrap tools out that would make easy work of this without cutting into the paint, or should I just do it the old-fashioned way with a thin, sharp blade and a slow, steady approach?
McDonald Signs
McDonald Signs & Graphics
I've done several of those for Fire Dept trucks. We clean the roll up doors really well then allow them to dry out good before installing the new decals due to liquid staying in the gaps. We also blow out the gaps with air
until we see no more moisture coming out of the gaps. After decals are applied we cut them with several new xacto blades cutting at an angle up on the top of the gap and cutting at an angle down on the bottom of each
gap so the vinyl is slightly away from the edge of the gap and dirt won't get under the decal. It's tedious and time consuming but it works.
  • Informative
Reactions: 1 users
Thanks so much.
jfiscus
Rap Master
Pre-measure the slats and pre-cut the graphics before installation. Use clear mask.
Otherwise, you run the risk of having to repaint the roll-up doors.
On an old, well-used truck with existing damage to doors you can sometimes get away with cutting the slats on the truck, but on a brand new truck, you have to pre-cut.
Obviously, you have to educate the customer on this and charge accordingly.
Reactions: 1 users
Thanks! That was my backup plan and I now think that I'm going to stick with that. I cut some 1/2" wide test strips with what I believe is the correct spacing. I'll test those on the truck first and make sure that the spacing is correct, or adjust the spacing as needed before finalizing the cut file. I'm only going to put gaps in the gold cut file and lay the black down in one piece. I should be able to use a plastic scraper blade to easily cut through cast vinyl. I'll post photos when the job is done.
I ended up not having to cut anything freehand on the trucks at all. I decided the best approach was to set up the vector cut files with the slits already in them, then just be extra careful to line up the decals with the slats. I measured as many slats as possible at once, then divided that dimension by the number of slats to figure out precisely how tall the slats were on each truck. You can figure out the rest. It worked out great and was a huge time saver.
I'm not sure how I forgot to take an overall photo of the gold on black but it would seem that I didn't take one. :(
Reactions: 4 users
Psylocke66
very clever solution
