Cutting graphics more than 5000mm..
Mata
Hi all
My FC9000 is driving me crazy. I don't think I have ever sent it a graphic that is over 5000mm snd now when I need to, it won't work. I understand the machine can do this fine but my machine refuses.
I'm using Onyx 21 and I am trying to cut a graphic that is 7500mm. I intend to do this using 4 marks as every time I try to do segments, it cuts the first part and then gets stuck on processing. Is this the only way I can do a long cut i.e. cut 5000mm and then cut the second 2500mm or can I do it in one go.
Also, can you tell Onyx the order in which to cut? I don't think this is possible in Onyx.
JBurton
Signtologist
Huzzah! To answer a question of yours, I don't think onyx will let your specify what to cut first. Cutting Master can, but only if you turn sorting off and stack the parts in order by hand, or with e-cut.
