Cutting Help Needed
RaceCutter
When I cut the vinyl out and weed it, there is always one little area thats still conected on each letter .... im guessing this is where it starts/ends .... is there a setting that i can change to make it pass that start/end point to ensure it cuts the letter out fully.
Thanks, Matt
chopper
it depends on your equipment, cutter- software,
what you need to look at is blade offset if you have a manual for you cutter
it should tell you how to adjust it there, if not look under the hardware section here and see if your cutter is listed and see if there is a thread on your problem, if you cannot find it please list the name of the equipment you are using that will allow you to have greater success in getting an answer //chopper
chopper
I think mine is at .05 I would try smaller if that wont work try bigger
you may need to experiment to get it right it will also depend on your blade, let me know if that dose it
...//chopper
