Cutting Master 2 VS FlexiSign
Help! I run on a Mac, cut vinyl on a Graphtec from Illustrator CS4. I just upgraded my cutting master to version 2, 1.60. Now, I am not able to cut vinyl and run my Mutoh printer at the same time. It says they use the same production manager.
Is there ANY way around this?
Thank you!
nopalito24
Sometime there is a conflict when you have CM2 and Flexi in the same PC.
Make sure that you close down cutting master while using flexi, and vice versa.
MediumPace
When I use both programs at once I need to manually change the command menu between GPGL and HPGL.
GPGL communicates with Graphtec software ala CM2. And HPGL communicates with third party software ala FLEXISIGN. I think I read that the more advanced graphtecs can change these settings via your PC or MAC settings, but my CE5000-60, you always need to change it manually.
