So I have the latest cutting master plug in for adobe illustrator and using a Graphtec fc-9000 and from what I can tell it only happens when using the datalink server. What will happen is it will cut maybe half the job and then stop and try and go to the next job. I have even tried running it again and it will stop in the same place. So I will have to set it up to "send directly to cutter" and it will work fine. I know cutting master has a lot of gremlins but has anyone ever had this issue? doesn't happen all the time.
