ljbutler1951
I have a couple of cutting problems. I design using Corel X3 and VersaWorks to print/cut.
When cutting, the blade does not come back to the originally starting point, leaving a minote piece of vinyl still attached to itself. I have been manually rying to make adjustments and have corrected the FEED part but can't get the SCAN part to line up right. I have even adjusted from one extreme to another and the cut line doesn't move. If you look real close, it also has a tiny twist cut to the end of the line.
Also when cutting, it doesn't cut every line. It misses the lines closes to the edge, on two sides. I have gotten to the point of putting a box around everything just to make sure that it gets cut.
