Cyan issue with printer
Happy thanksgiving to all. I'm running a new PrismJet54 that I purchased in August from signwarehouse (my second printer, my first printer I ran for 16 years before this upgrade). I'm not having any luck hearing back from their tech department and thought I would ask here. I'm printing a box truck I printed 1 full side, the front and the back with no issues this week. The last side im printing started to act up. The section of wrap that I'm printing has 80% cyan prolly 20% black on the first 4'x80" panel.
This week I ran a ton of black and yellow prints with no issue. The issue is only with Cyan in a longer run. It started out with some banding halfway through the print (similar to the pic).
I did a manual clean and a heavy clean. When I ran some more vinyl it began to spit cyan.
I did another manual clean and a light clean on the machine. I stepped away from printing the wrap and the next few job I ran had minimal to no cyan, they ran perfectly.
I was hoping the bug may have been worked out, I continued back to printing the wrap again and I got this same banding about 4' into the print job. (looks like I'm getting a build up on the printhead of wet ink) For someone that know what they are looking at I believe the problem can be diagnosed maybe by the image of the print head I included. There are 2 long cyan areas on the print head that don't look right to me.
That ink build up isn't normal for sure. Looks like your wiper isn't making contact with the head surface. I'd check the wiper to make sure it's making solid contact with the head during cleanings and replace if it's not or it's older than 6 to 10 months. Also check the flushing pad next to the wiper and make sure it's not swelling up enough to touch the head surface. The head surface should pretty much be free of ink for the most part. Those cyan strips are actually where the nozzles are and look normal to me.
I'll double check, but I believe the wiper is making good contact. When I run a manual clean the print head does clean I'm almost certain.
Thank you for the input, it is sincerely appreciate. The wiper is practically new my machine was purchase in August. Signwarehouse did get back in touch with me and they believe it is a humidity issue? I currently have too low of a humidity?
I haven't had a chance to get a humidifier yet but do intend to. They recommend me keeping a constant 50% humidity.
Note: I was getting towards the end of my Cyan cartridge (it was endura ink, I have evolved back to using genuine OEM mutoh carts) so I swapped it out today for a new Mutoh Cart and did successfully print some smaller jobs with a good amount of blue. I have my wrap printing again with my fingers crossed it may have been the endura ink that I was running?
Yeah that looks like a clean new machine for sure. I'd say they might be on the right track with the humidity, especially if your environment is far out of spec. You should be anywhere between 40% and 60%RH. Out of that range, strange things can happen.
It's possible it's the ink but I don't hear much about SignWearhouse ink. If the original Mutoh cartridge works, that very well could be a sign the ink was bad or more likely, just a bad batch or expired.
Thank you again for the feedback. I successfully printed 1 of my last 80" panels and I'm 1/2 through the second with no issues thus far. My fingers are still crossed. I did order an anti-static mat to help ground the printer.
