Degassing a 50m roll of SAV
uv
Hi, just got a eco sol rs640
does anyone have any ideas on how to degas a 50m rool lf self adhesive vinyl?
Cheers
TXFB.INS
Heh I must be tired... I read "stand on it" :ROFLMAO:.
You can throw a fan underneath it to speed up the process. There have been a few threads about "outgassing" and I believe some members posted pictures of their drying set ups.
This is what I use when I want to make sure prints are 100% cured before laminating... I just happened to have an old router table that worked out perfect. It aint pretty but it does the trick. Just make sure you loosen the roll so there is space in between each layer. I realize with a full roll this will end up being a big roll once loosened but if you use the large (slotted) roll holders it should fit.
:goodpost:that is a great DIY project will be "borrowing" that one
MikeD
Its a good idea to stand it on a raised fan or at least a raised grate, as solvents are heavier than air, and there is a chance they could pool up at the bottom of your roll and hurt the vinyl or adhesive
5Star
+1 :thumb:
I stand mine on strips of timber (2x1) to let the solvent "fall" out of the roll. Unwind your roll as much as you can - like 18" - 24" diameter. It's a Must, especially for laminating or die cutting.
uv
Thanks Pat!
