Cheese Pie
Good afternoon,
I am hoping that someone out there is able to help me with a problem I have with my Gerber Dimension 200. I have had the machine for a little over a year now and through trial and error and a little information on the internet I have managed to get this up and running quite successfully making labels and small signs. I have not been massively adventurous with Art path but have used all options in the menu to make my parts. Engraving and female work exactly as they should and the cut follows the line shown on Art path. The male cut continuously cuts in a way that does not follow the outline in the software and I am unable to find any information in either the Dimension 200 user guide or the Art path user guide that explains why it does it and how to rectify it. For the purpose of this exercise I will explain as if i have a 2mm endmill loaded into the machine. if I take a draw a basic square in Composer 8 and go to art path and select engrave, it will show a line being engraved flush to the line drawn and when the machine runs, it engraves exactly as shown on the screen. Similarly, if I choose female cut, it will show a line 2mm inside the original box line and engrave as expected. However, when I select male cut, it will draw the line 2mm outside the original box line but when run it does the following. It will trave to the top left of the box and start the cut exactly on the box line (same as engrave) it will travel down along this axis and then travel across left to right, again exactly on the box line and not outside it as it should. It will then overshoot the line past the 2mm that it should do and travel up outside of its expected cut along the axis. it will overshoot at the top of the box and then continue along the Y axis cutting outside of the parameters that are expected
see below for example
This is what I expect to get done
This is what happens.
I appreciate that this is an old machine and has very little use in the modern world of CNC, however I am a dinosaur myself and like to tinker and see if I can make things work but this is frustrating my now, as I am unable to fix it.
Any help or advise would be greatly appreciated and hopefully there are a few people out there who have had experience with this machine or the software.
Regards
Rob
Regards
Rob
