DLIcan printer
deca
Hello
Anyone familiar with the DLIcan hybrid printer range? Pro's and con's? Rip software? Quality? Support?
Smoke_Jaguar
Looks like a generic Chinese 'kit' printer based on Gen6 heads. Probably Hosonsoft or clone boards. Might be worthwhile with really good support, but a brand like that is dodgy at best. If you love getting into the weeds on tech and figuring it out yourself, it might be a good deal if under $40K.
dtfonestop
Smoke's read on the hardware matches what I'd expect from that class of machine, so the real decision is less about the printer and more about who stands behind it. Before I'd sign on any hybrid in that range I'd want these nailed down in writing:
- Exactly which heads and how many, and what a replacement head costs and how fast it ships. Ask if they keep heads, dampers, capping parts and boards in stock in the US, not just "available."
- Which board and which RIP it ships with, and whether the RIP license is yours or tied to the dealer. Check if you can run the RIP you already use.
- What the warranty covers on heads specifically, and who actually shows up if it goes down. Install and training included, or extra?
- Run your own files on your own substrates. Send them a rigid job and a roll job with white, and look at banding in solids and how the white holds up, not just their demo prints.
- Ask for two or three owners near you you can call. Their answer on support response time tells you more than the spec sheet.
If local support is the big worry, it's worth getting a second quote from a US dealer who stocks parts here so you have something to compare against. You can see nearby Audley dealers, for example.
What are you mostly planning to run on it, rigid board or roll media, and what part of the country are you in?
deca
Do you have experience with the brand and support. What is your opinion based on? I'am in Belgium located
Smoke_Jaguar
Familiarity with the brand, no. Familiarity with the hardware, yes. I am located in the dumber part of the United States and do not offer support overseas due to logistical issues. Mainly, nobody has made a USB cable that properly works over distances in excess of 3000KM.
dtfonestop
Fair question. Not with DLIcan specifically, I haven't run one of theirs. My points come from the general pattern with hybrids built the same way (Ricoh Gen5/Gen6 heads on Hoson-type or similar boards): the hardware itself is usually okay, and what makes or breaks ownership is how fast you can get heads, dampers and boards, and whether someone who knows that board can actually help you when it throws an error.
Also, ignore my US dealer comment, that doesn't help you in Belgium. Same idea applies though: find out who in Benelux or nearby in the EU actually stocks parts for it and has a tech who has worked on one, and ask to talk to an owner or two in your region before you sign.
Is the seller you're talking to local, or would it ship direct from the factory?
