Does anyone on here have a Mutoh 1627 mh? If so do you have a problem with your inks?
Petra Campbell
When my printer gets 1/3 low on one of the inks it basically wont let me do anything. I cant put into sleep mode so basically I have to unplug the machine. I feel it wastes inks because I always have to change the ink when there is 25% left in the bag! At $200 a bag that is about $50 that is wasted.
dudeinthemoon
You should never unplug it, it has autocleaning and maintenancing cycle to prevent drying printheads. Every inkjet printer must be powered all the time after initial ink filling, and it will always waste a certain amount of inks to clean the heads
If the machine is flagging the cartridge as empty before it's actually empty, you might need a new maintenance station. The machine only guesses at how much ink has been used so if the amount of ink it thinks it's pulling from the cartridge when doing cleanings is less than it expects, it flags early. Call your ink supplier. They should be able to get you cards to use the rest of the ink.
