Duratex Blockout Adhesive Vinyl
ProntoPrinter
Has anyone used this vinyl? I have a customer opening an arcade who wants their glass storefront covered in vinyl graphics to cut down on glare. Ideally, they want the adhesive to be black, and this is the only printable vinyl I can find that is a blockout and has black adhesive. This stuff is crazy cheap too, which concerns me. We've used Duratex banner material and have never had issues with it.
I'm only familiar with GF 218 WindowMark, and that doesn't come with black adhesive.
Thanks in advance for any input.
DChorbowski
Pixel Pusher
I have used it in the past when the 3M blockout was not available or i needed a base size larger than 48". Neither of these applications were for very long term use, only a couple of months at best. The only complaint that I had is that it was not a total 100% blockout when compared to the 3M 3635-20b. I would say its closer to a 90-95% blockout. If thats acceptable in your application that it should be fine for a few years. We have also made our own blockout by just layering up white vinyl ontop of black vinyl which worked great in a pinch. Just make sure you use the same quality of vinyl for each layer.
Foremander
Before you go full blockout, ask what they actually need inside. If it's just glare on the screens, a perforated window film might do it. The back is black, so from inside it reads dark and cuts the glare, but staff can still see out. A 70/30 perf blocks more light than the usual 50/50.
If they really want it solid, the black adhesive is the right call, it looks clean from inside. If it goes on the outside of the glass I'd laminate it. And on a big sunny storefront I'd ask the landlord about the glass first. Dark full coverage gets glass hot, and some insulated units don't like that.
Also worth checking with the city. A lot of them cap how much of a storefront window can be covered.
  • Agree
Reactions: 1 user
