DX5 decoder version
Thanks everyone for responding. I believe it is a locked head as I have installed the r1900 head and the original 2 times each. the original head works fine and the r1900 head pulls a code each time. The problem with the original is that the head is clogged about 70%. I have two DX5 heads (now 3 including the r1900) one from a 4880 and the 7880. Both of these heads are clogged about 70%. I had them both soaking in distilled water for two weeks while I was away since both heads had some jet clogs. I would say only about 10% blockage. I believe I damaged the heads by flushing and backflushing them with windex before soaking them in the water. I just can't imagine both heads would get worse just by soaking in distilled water.
I might try the decoder and see if that works and I appreciate the responses.
I also have the 7880 and currently have an older model R1900 DX5 printhead (IF33V). It has been working great. I have two different decoders and both seem to function the same (one is ver 1 and the other ver 2, the version two has the connectors all facing up). Unfortunately, the black channel is spitting so I had to turn it off. The head ran into the surface I was printing on. I have two new printheads, one from a R2000 (IA0770) and the other from a new SC-P400. Unfortunately, the R2000 has the gaps even with the decoder and the SC-P400 is giving the 001001B overheat (won't print ink at all). Buzz kill. I plan on posting more later but thought I'd share a bit now. The DX5 head in the SC-P400 will require a new type of decoder as it is very different (IF464V).
So I think since yours gave a 001001B error, you have a cable that is bad or misaligned in the connector. Or, Epson has somehow changed those older printheads with newer technology because it should have printed but would have given gaps at 16" to 18" in head travel (in uni-direction printing mode and two sets of gaps in bi-direction mode). Maybe someone had changed that printhead and sold it to you. I think that's what happened on the R2000 that has gaps because I have had a previous R2000 and it worked fine. Strange stuff. Epson is keeping us guessing. More later.
