Does anyone have experience with the H1625? We are having issues where it won’t talk to the print head board anymore. Unfortunately our service team has advised that we may need a new print head control board and it is 15,000 plus labour so they are advising not to do it because the machine is old and it may not even fix the problem. One tech thought we should should try a new tower so we are working on getting
windows 7 on a new tower and see if that fixes anything. For years we have had problem like this and moved the dongle around the
computer and it has temporarily fixed the issue.
The fact that moving the dongle around has "fixed" it for years makes me think the head board may not be the real problem. That sounds more like the PC side: a USB controller or port that's going flaky, power-saving settings shutting off USB, or the interface card or cable between the PC and the printer.
Before spending anything on the board, I'd try the new tower. If you can, move the interface card over from the old PC instead of buying a new one, and turn off all the USB and PCI power-saving options in
Windows and the BIOS. While you're at it, reseat and inspect the data cable between the PC and the printer at both ends. Old connectors and cables on these machines get tired.
If it still won't talk to the board on a fresh PC, then the service team's read is probably right. At $15k plus labor on an older machine, I'd at least get pricing on a newer UV flatbed before committing. You can see nearby Audley dealers if you want a comparison.
