Enfocus Pre-Press Software
zspace
We have several customers that submit large quantities of randomly sized files. For example, we received 100 files on Monday for a job due tomorrow. The files have to be checked, sheeted (some for double sided), nested, and cut lines added before going into print. Does anyone work with Enfocus or othe Pre-press software that claims to check resolution, add bleeds, add cut lines etc.? Can you share your experience?
Pauly
Printrade.com.au
Enfocus pitstop server is probably what you need.
That will check bleeds, add beeds, add cut paths. Etc (you'll still need to set it up to do that)
Pitstop server comes with a basic version of switch so you can rout jobs though different folders depending on variables.
Nesting you'll need tilia Griffin on top of that.
Check resolution can be a tricky one as you're either checking to 1 specific size or have reference data.
If you need reference data if the file are different sizes etc, you'll need extra modules for Enfocus Switch.
There is a huge learning curve it all functions.
Also it ads up very quickly.
