enviromental match
how do you do the enviromental match? i've read a few times now about once you print, let to dry/out gas and laminate, you then do an "enviromental match"................we've never done that. so, how do you do it?
Double Diamond
Under menu... arrow down or up till it sais enviro match. Hit enter. It runs the y axis. Takes less than a minute. It's good for a print, lam then cut job. I think it calibrates itself at it's current condition like temp and such and compinsates for it. Hope it helps. J
oh i forgot to ask.............do you load in the prints with lam,.........then do the enviro match? or.......before you load in your prints?
JRSdecals
If you have a VP540, i don't think you will have that option in the menu. With that printer Roland started making the machine do it automatically everytime it reads the media width.
Jeremy
when your printer takes the enviroment it is in, for example the room it is in and adjusts for any temp/humidity changes etc so the material you have reloaded into your printer is cut correctly.....................i think i explained that ok??!!!?!
Zazzess
I understand :) thank you :peace!:
Roland
This function is made automatically on VP-540 every time the setup sheet is made. The printer calibrates itself (encoder setup etc...) considering the external factors : humidity, temperature, light (I guess) a.s.o.
