EPS border Flexi 8
DizzyMarkus
I seem to have reset to default :0( -- I can not remember where the setting is to set my eps border. Rightnow if I have a cut line, and save as eps, it will cut off the edges. Thanks greatly for any help,
Markus
Cyw
Markus, are you sure it's not your eps margin settings in VersaWorks?
That margin needs to be changed in the queue settings before you bring in the eps file.
On the top toolbar in VW select Edit/Queue Settings and go to File Format. Your eps margin setting by default is 0.0 That's no good It's got to be set a little higher.
Diane
DizzyMarkus
Awsome -- sad when it takes just that much to bring it all back hehehe . Haven't had to mess with it but new it was somewhere :0) thank you very much,
Markus
I was having to do transparent rectangles to make it larger -- what a pita :0)
