Hi everyone, maybe someone here can help me fix my printer,
So from night to another day my white slowly slowly stop printing, first time i tought is printhead died on me (before night before i turn off the printer i got 100% nozzle check) but then i check my inklines and i see i dont have inkflow in 1 of my white ink line, so first time i tried to do a power clean , not helps, after i cleaned my capping station and the tubes with cleaning solution maybe was blocked, everything fine , put back , powerclean , the problem was not solve, okay , then i take out the damper unit and i tried to pull ink from damper maybe i have air in lines, not coming , so i take out the damper the inklines everything washed out with hot water i put back inkcharge but that 1 line with white ink not doing nothing, after i see in half line i have ink in another half nothing so i changed the dampers and the cartridges today, but i have the same problem... any idea what can i do?
