Epson Edge Print pro RIP can generate Summa F regmarks?
Peter Brady
Hello,
Is there anyone who uses Epson Edge print rip with summa F and managed to adjust/add or found a workaround to generate summa F circle marks on tile jobs within Epson Edge print RIP?
We have few epson machines and its kinda time consuming to layout the tiles semi manual prior exporting to pdf and importing into the rip software.
I know Onyx its capable, but i was wondering if you have found any solution for a similar outcome with Epson Edge Print RIP
balstestrat
Problem Solver
Make them manually before importing the file or change to a different RIP. That's about all your choices there.
ikarasu
Hello,
I could be wrong but I don't think Epson does print and cut.
If you use illustrator... For $25 this program will auto nest for you, takes seconds.
Peter Brady
I will take a look, thank you,
What I need is to automatically split a huge artwork in multiple overlapping sheets , applying cutting marks, and crop images on each sheet upon exporting, not only clip mask them. And this should be done by inputting all the data into a panel.
I have struggled a bit with some actions and small scripts, ( i dont know scripting) and managed to get to about 70% of what i need, but still not there yet for a fully automated sheets export.
unmateria
Hi :) im not sure since i dont use it for vinyl cutting, but I think e-cut for coreldraw (and i think illustrator too) can do it. They have a test version and is very cheap (i use it a lot for other tools it has)
