We have tried a few things...plus a few basic cable, restart, etc
We have sent an email to Epson through Grimco, waiting to hear back
Raise the media loading lever and remove the media that is currently loaded Make sure the media is at least 11.8 inches (300 mm) wide Turn off the Media Size Check setting Try printing again
Turn the product off and then back on again Check for and remove any jammed paper or protective materials from the product
Check that the printer is connected to power, plugged into your router, and turned on Make sure the power and ethernet cables are plugged into the correct printer ports Verify the printer's orange ! and paper lights are not lit Run the Head Cleaning utility If colors are still incorrect or missing, replace the color ink cartridge If the problem persists, replace the black ink cartridge
