Epson stylus pro 7000 maintenance tank
knucklehead
Does anyone know of anyone who sells a replacement maintenance tank for this model? I've been told how to clean the absorbant stuff in it, but if I could just replace it I'd much rather do that. I have looked for one, but no luck so far. Or if one from a different model would work? Thanks Mike
reeki
the maintenance tank is fixed in the printer , you have to losse the 4 screws of the front guide and then you can see the maintenance tank (holder) its big and from black plastic , inside you find the waste pads . they can be orderd as spare part or you can order the complete maintenance kit including the pump and cap assy.
reeki
maintenance kit part number : 1440977
number 402 is the waste box (on the image included)
1050828 are the POROUS PAD,INK EJECT alone ( number 403 )
  • C299-MECH-14.pdf
knucklehead
Thanks Reeki, I would rather just go ahead and get the whole maintenance it, and do a complete job while I'm in there. I'll contact Epson and see if they have the parts. Thanks a bunch. Mike
knucklehead
Thanks Rooster, I've heard about that. May be the route I have to go until I find someone who actually has the other parts too.
Rooster
Try www.nationalparts.com.
I buy all my epson printer parts through them. They've always been in stock with top notch customer service.
But seriously use the maxi-pads. They work like a damn and are waaaay cheaper than the foam pads epson sells.
happydays
nice reading as im getting the maintenance call 0100 so the pads work ?? and how do i reset the counter guys ?? regards adam
