Error 08
artbot
you mean what is the encoder sensor? a: it's the IR sensor that rests behind your head carriage that reads your encoder strip. i'd start by just blowing some air at it with one of these canned air computer cleaner cans.
nardDesign
you know the error shows on display when cutter goes to the end, then it's showing up the error. What should I do , Do I need to change something or what?
very thanks
Nastev Done
I have changed linear encoder strip, linear encoder sensor 2 times, but nothing happened. I have changed the Main board, but that message still appears on the display. I`m trying to resolve that problem. And if I had some informations i will write.
shifil_mimak
Dear same here,, error 08,,linear enc.sensor,,,, even i replaced the encoder sensor,,no change ,,,, and for me this error happens on booting,, so nothing can be done,,, any hope ??? ,,,pls share,,thnx.
Ponto
*** See my thread "MIMAKI WOES" in this folder**** .... this "issue" is popping up quite often it seems!!! JP
