Error 2 on Gerber Edge 2
Chosen23
One man shop
Hey all, I have a Gerber Edge 2 that has been sitting for several months. I go to use it and it sits in warm up mode for several minutes beeps and I get DATA ERROR 2. I tried all the basic things but not having any luck.
Thanks in advance.
netsol
when you have an hour to waste
power off, unplug
vacuum out any dust, one at a time CAREFULLY unplug ever cable then plug back in. reseating cures many problems
if you aren't afraid of a project, take boards out 1 at a time, clean bottom of board with 91% isopropyl and a tooth brush
look for a "ringed" solder connection that might need to be resoldered
the first part will probably fix your problem
Chosen23
One man shop
power off, unplug
Thanks for the advise I will try that out for sure!
