ERROR Y CURRENT
Rafy37
HELLO, NEED HELP, having problems with my mimaki cjv150-130 giving error 404 y current and sometimes 402, i have change capping, dampers, encoder strip, encoder sensor, motor, data cables, pcb board, gear belt, and still giving same error!
zopylote
why you changed all those parts? because of this error?
error is in Y motor in mimaki is feed motor... maybe you have a big banner material heavy roll just loose media or paper jam or Y motor already gone
Neil
You can increase the Y current within the service menu.
The problem is, you need to be able to start the machine without getting a Y current error, to be able to get into the service menu.
Talking from experience, I manually reduced my machine's Y current, trying to reduce the loud whining noise as it moves the head.
It all went well - until I reached the point that it couldn't move the head without tripping the Y overcurrent error. There's no way back from that, so I re-uploaded my parameters to re-set it.
Mimaki engineers think of the printer from the side, not the front like most end users do. So the Y motor in Mimaki's is the one the moves the head back and forth, not the print feed. It's annoying, I know.
If you boot up in System Parameter Mode by holding the left and right keys while booting up, you can change parameter number 45: Hash to 1 and then reboot in service mode. It will boot up without initializing the motors and ignore errors.
If you've changed all those parts and it's still giving the error, the chip that runs the motors on the main board might just be fried. That or there's a ton of drag on the Y bard for some reason.
