For those running Estimate 2.0 on
Windows 10, did you do a straight install or the VM method? Since most are likely to be switching to
windows 10, this may get more attention for Estimate users. I have tried installing it once and it would just lock up. So I'm curious how you got it to function. Thanks
When you installed it, did you try it in compatibility mode for XP SP3?
It will only be a matter of time for a program with XP as the min requirement won't run on Win 10 (as that means that it was compiled and built on XP). I've known others to get a 9x or XP program to run in Win 10 when it first came out and then an update caused something that caused the program to not work right or the OS deleted it from the
computer and gave them a msg in the notifications as to what happened.
As much of a fan of VMing that I am, I looked at the specs for Estimate 2.0 and the specs that it needs to run, in my mind make me wonder if it's worth it, especially if it's the only program that you need the VM for. Estimating 'software' in general can be replicated (quite nicely, depending on how much time/willingness dedicated to it) in a spreedsheet file at the very least, or if you are decent with HTML, CSS and JS as an Electron desktop app (what I did and I have it set up to also build for
Windows if for whatever reason I have to go back to that OS as my main OS). I only suggest this as normally it's just easier (and cheaper (not just thinking in terms of money either, but time spent)) to just update the software, but after looking at their prices and it being subscription software, I don't think so.
