Estimating software for a palm?
ENTDesign
If you used Chris - GraphicExtreme's - excel spreadsheet estimating software you could pull the spreadsheet in using Documents to Go. The biggest problem is that you don't see many cells on screen and have to scroll abit. I think my screen shows 4 columns by 6 rows at a time if I want them big enough so I can read the numbers, but you can adjust the size.
anothersign
DUH i am a noob
i just downloaded your trial this morning just did not relize it could run on a palm. i will be making the purchase soon thanks so much for all your help.
jgolo
Did you..
try the "Pro Version" or the standard version?
Idea Design
SignCalc...
As I don't have a printer, I bought the cut-vinyl only version SignCalc. Loaded it up in DocsToGo on my Treo 650, but cannot make modifications to the sheet as the palm says its a locked file.
I tried to unlock the pc file, make it not read-only, pretty much everything I could think of, but it appears unusable on my Palm.
Any ideas Chris, oh master of Excel?
ChiknNutz
I've had a lot of questions on the subject, but since I don't have a Palm, I don't know how to go about prepping it for one. I would certainly give it a go if I knew what needed changing?!?!
