New Product Eufy E1 desktop UV printer
ikarasu
In talks with a Chinese maker to bring in a few 24"x36" 3-head (XP600) flatbeds in and cost on those is only like $4K, though freight is added as well as tarriffs. The little 12" flatbeds are around $2k with a single printhead. Main thing is going to be how well they implement software. Though, most Chinese printers can run in Flexi and Onyx these days as well.
Ask / make sure your printers can be used with Flexiprint. The chinese software sucks... constant crashes and is unusable... The prints are nice, and the raised text is good, my only regret is the software.. Pirated and glithcy software, with broken english all throughout it. A lot of models use a newer board where flexi will work, but a lot of vendors still use the old board where it doesn't... so If software is important to you, its worth a question.
I'd also ask if its genuinelly 24x36... china uses metric. One reason I opted for a smaller flatbed was because their "24x36" was really "60x90"... so I couldn't print on a 24x36" Board, which was my main reason for wanting a larger flatbed.
Smoke_Jaguar
Yup, nice thing about knowing how to reconfigure the Hosonsoft and other controllers, if the bed has the physical space, can eek out the extra half inch or so. We're just ordering frames, motors and control systems. Doing the tubing, heads and other parts sourced from other vendors. As for the software, yeah, it can suck. Thankfully most language pack files are easy to rewrite, did that with a BetterPrinter controller and holy hell it helps with the sanity. If you still have the flatbed, see what controller it uses, might be able to recalibrate things to get more depth/width.
dreko
Hmmm too bad LogoJet's 60x90 sized flatbed was priced at a more honest price point.... I guess I could say this about quite a few print manufacturers. I'm realizing how crazy
high the artificial price markups are on the printer/hardware. Oh well, capitalism at work, fortunately we're witnessing how the Chinese are going to exploit this area appropriately.
Smoke_Jaguar
The LogoJets are just Chinese printers. The printers are basically kits, so going to see boatloads of random brands selling them. Like Xante, Procolored and all them. Some claim to be made in the US, but are just assembled here, and they put crazy markup on them.
dreko
Yes, Logotjets are chinese printers, however, the company has priced them as though they were all manufactured here in the USA, with exorbitant pricing for what they are... IMO
With 3D printers, 3D scanners, Drones, Robotics... we're seeing the price for the hardware come down. The 4k printer price range is more realistic for a 24x36 flatbed with decent software. If I understand things correctly, the software
on your 4k import is not great....
DPICopy
Any recommendations for a decent quality 2x3' flatbed somewhere around the aformentioned price range (up to $10kish)? Would need to be compatible with Onyx. TIA
ringocat22
I've been looking into buying a flatbed UV once we get into a bigger space. Can't afford a 4x8, but maybe a 2x3 or 2x4...any recommendations?
Smoke_Jaguar
We're test marketing them to a few local shops here in OKC. Lets me do quicker support and training. Still working out heads, XP600s are great, but dissolve over time in UV ink, so they have a 6-ish month lifespan but are around $120. UV heads like the i3200 U1 are closer to $1k but are almost double print area and way more reliable. Can also heat the ink on i3200 with external dampers and get way more UV ink options.
bpp
lmk when available
balstestrat
Problem Solver
How its made.
They have a custom printhead assembly to switch with a solenoid and feed cleaning liquid straight into the nozzles. Interesting design.
Smoke_Jaguar
I am lazy and use hand actuated valves on DTF stuff, since those clog super-fast. UV ink is probably the least likely to clog in my experience, with the exception of white inks.
Smoke_Jaguar
8 seconds in, yup, it's an XP600 head. Figured.
Scratch that, 8 channel head @ 11:45 shows F186000, so an Epson DX5 unlocked.
ikarasu
Explains why it's so slow. Good because a new head is cheap... Although that head doesn't look stock, so I doubt you can just drop any XP600 head in.
Also means aftermarket ink may be a thing eventually.... which is somewhat good.
I can see some people buying it to do small braille signs with.... I can see lots of crafters buying it to make keychains / other stuff with their laser cutter, only to find out no one wants to pay the price they need to charge to make it worth it...then there being hundreds of paperweights. I see this more like a sawgrass printer.... The only difference is anker is going hard on the marketing, theyve given away soooo many units to get free publicity.
But for anyone who's looking to produce more than a few signs... I'd go with a chinese XP600 head printer, costs a bit more...and the software sucks, but you can get a 2 head XP600 for about $3000 USD.... In theory it should print almost double the speed, be the same quality... Ink is like $40 a liter.... And it'll be more repairable if something breaks down. Onlything anker has going for it is the software.... And maybe the build quality, They do produce some nice stuff.
Smoke_Jaguar
My bad on the XP600, it's a DX5, which is like $1k compared to only $150 for an XP600. Might be worth grabbing some when Anker/Eufy abandons them for parts. After the disaster of a 3D printer they kickstarted, I guess they changed names. As for their circulator, using a magnetic stir bar is hilariously stupid. White ink gets quite thick as it settles and stir bars are not great for that application. No circulators either, and everything is glued/clipped in under plastic panels. Lots of parts I recognize from AliExpress too. I wish every printer company would bring in influencers to show all the craziness they make.
For the real dirt on their subscription model, Hackaday covers some. The comments are brutal as they're not beholden to the Eufy agreement to get a review unit. Seems they're hedging their bets on getting as many kickstarter preorders as possible before the word gets out.
