FB500 - Error code E-MD-9 Motor driver board initialization failed bootloop
Isaac_K
Our FB500 seems to be stuck in a bootloop due to an error during initialization.
Screen will show "Initializing 48% - 75E4-B" then error out with error code "E-MD-9 Motor driver board initialization failed".
Next logical step is to obviously replace the motor driver board, but error codes are not always as they seem. Looking to see if anyone here has cost effective solutions to test out before going that route.
Thanks in advance.
Dylan Phillips
Thanks in advance.
Any resolution to this issue ? We're running into the same thing with our FB750.
Key difference is our motor driver board fried, we replaced the board and are now receiving this error in return.
Isaac_K
Did you guys have any luck with this?
I can’t recall exactly and had to look back through some messages and invoices. It seems we ended up going into the BIOS and got lucky. According to my notes, we were double checking BIOS settings and thought we did not change anything. However, it's important to note we did save and exit BIOS. After restarting the machine, it passed initialization successfully.
After booting up, we noticed a few new symptoms:
  1. The head moved significantly slower
  2. The head would travel the entire length of the rail - even when the input size was smaller.
I believe we replaced the carriage drive timing belt to remedy this. We did not end up replacing the driver board.
I hope this helps!
Kreminskyi
Can anyone help with this:
iob.c(04712)Programming MDB (27907 bytes)...
TRACE :000099331: iob.c(04862)MDB FPGA configuration successful
INFO :000102329: iob.c(05018)CheckCounterField: 2988000 uSec interval (794624 to 843776)
ERROR :000102342: iob.c(05022)CheckCounterField: FAILED, bad value
ERROR :000103217: mdb.c(00235)MDB configuration failed
ERROR :000103225: mdb.c(00292)mdb_setup: Failed to initialize the mdb.
INFO :000103236: mdb.c(00183)mdb_cleanup()
ERROR :000103243: mdb.c(00312)CODE: E-MD-9 (0x01700009) : Reported 1 Times
Motor driver board initialization failed:
CAUSE: The software detected an error
