Fc5100-75 Not Finishing Long Contour Cuts
Knep
The panel I am cutting is 135" inches, it goes to maybe 96" and stops cutting, pauses, moves to the opposite side of the letters and starts cutting in the other direction. I am using Flexi 8.1 pro, I check and my roll size is like 1,900 inches in production manager, is this a setting with in the plotter maybe?
chrisphilipps
There should be a setting on the Cutter called Page Length. Set that value to something longer than your job and it should work. On the newer cutter it is under the Menu labeled Area Parameters but I am not sure what it is under on the FC5100.
