Need Help FC8000 seemingly randomly cutting jobs twice when set to 1 copy
Omega Plotting
Hello, I operate using Flexi Print&Cut and occasionally my Graphtec FC8000 will immediately restart a second copy of the same job after concluding the single copy sent. It is not resetting the vinyl or double cutting lines, just continuing as if I have set for 2 copies when I do not.
This seems to happen randomly a couple times a month, and I've basically just started a habit of watching closely when the job finishes and stopping it manually if it continues into a second copy, but obviously would prefer to not have to worry about this. Searching online returns a lot of people discussing double cuts due to overlaying paths, but that is not my issue.
Thanks for any advice or things I might check on the Machine or the computer I use to manage it.
ChaseO
I had a similar issue one time. My issue was my mouse was going bad and I was actually double clicking the send button without realizing it. It may not be your issue, but at least rule out the easy stuff.
  • Agree
Reactions: 1 user
