FC9000-160 super aggressive at pulling from the feed roll, anyone know how to slow it down?
Kernersville Vinyl
We print a lot of trailer wraps so we will have 150' rolls with 100" panels that need to be cut out, but one thing that is a big issue is the machine jerks the feeder roll on the back so hard it can throw off the feed rollers, and cut wrong, we are finding that we must run the next panel forward and make it loose for it to cut correctly, I just can't imagine that as wonderfully engineered as this machine is that not jerking the feeder roll would be overlooked so spectacularly... am I missing something on how to prevent this machine from doing this?
unclebun
You have to prefeed vinyl on a roll feed cutter (i.e. you have to have the length of the cut unrolled from the roll before starting to cut.)
  • Agree
Reactions: 1 users
JBurton
Signtologist
If you're running different panels, set up the 'advance after cut' to be 100". This way it will finish the first panel, then advance to the other end of the second panel. You can then run it back to the beginning of the second panel, cut it, and it will advance to the end of the third. It's not perfect, but it's an option, and should prevent any slipping during cutting operations.
Precision
SoCal Signmaker
Sometimes the machines don't like the weight of the roll. So we will make sure there's enough slack that the roll is stressing the cutting knife (that's the operator duty).
You can also check that your pich rollers are set correctly.
DChorbowski
Pixel Pusher
You can turn on a auto pre-feed. Also your initial speed settings on the plotter will affect how fast it pre-feeds.
Press the [PAUSE/MENU] key. MENU screen is displayed.
2 Press the [4] key (MEDIA). MEDIA SETTING screen (1/2) is displayed.
3 Press the [2] key (AUTO PRE FEED). AUTO PRE FEED screen is displayed.
Press the [1] key (OFF). AUTO PRE FEED setting screen is displayed.
5 Press the [1] key (ON) or the [2] key (OFF). AUTO PRE FEED will be selected and it will return to AUTO PRE FEED screen.
6 Press the [2] key (FEED LENGTH). FEED LENGTH screen is displayed.
7 Press the POSITION () keys and increase or decrease the setting value.
8 Confirm the setting and press the [ESC] key (PREVIOUS). FEED LENGTH is selected and return to AUTO PRE FEED screen.
SupplementIt will return to MEDIA SETTING screen (1/2) without changing the settings when you press the [ESC] key (CANCEL).
9 Confirm the setting and press the [ENTER] key. Setting will be confirmed and it will return to MEDIA SETTING screen (1/2).
