Fexi 12 SP5 and Gerber GSXplus
Stour
Just updated to Flexi 12 SP5 and am having issues with my Gerber GSX Plus. I have tried both the GSX Plus Driver and the GSX Plus HP/GL Drivers.
The GSX Plus Driver Glitches and runs all rough. The GSX Plus HP/GL runs smooth but stops after a bit and light blink and beeps.
I'm Running window 7 pro. Serial port are set to xon/xoff and i have the fifo buffer unchecked.
The gerber was running fine with the GSX Plus HP/GL driver before I upgraded to SP5
Any help would be great.
FrankW
Specially with older plotters, with plotters which have small internal buffer memory, I would suggest to activate fifo. What was the last Flexi-Version which have worked? What happens if you drive the plotter with the HP HP/GL-Driver?
  • Agree
Reactions: 1 user
Stour
Hp GPGL & HP HPGL/2 drivers didn't work. I tried turning on fifo and had it set to high buffer and low buffer, still stopped in the same spot.
was working with Flexi 12 I believe it was service pack 3
Stour
Well after spending all weekend going through the gerber drivers and serial port setting. found one that seems to work. Even though I have a gsx plus. I found that the GS 15 plus HP/GL worked with flow control set to xon/xoff and the fifo buffers set to low on both the receiver buffer and transmit buffer.
