Files/jobs not showing in onyx x12.1
Pauly
Printrade.com.au
For some reason, no jobs are showing in onyx. i can open jobs and print current job but i cannot see anything on my screen. And also cannot see buffered jobs.
I deleted the files in my work folder, but it didnt help.
Ideas?
Thanks.
Bly
Have a look at how much disk space you have set for auto deletion.
I have an issue with tiling in Job Editor.
I think only with vertical tiling.
When manually adjusting tiles when you move one tile it throws all the others out rendering it useless.
OnyxDoug
Hi Pauly,
I'm not sure this is the answer, but just below the printer list in Rip Queue there is a "Show Jobs For" pull down menu. If this is set for a specific printer that has no jobs pending or buffered you will get the behavior you described (e.g. you can still rip jobs for a printer other than the one selected, but you won't see anything in the queue).
If this doesn't help, please contact Onyx support. We don't want you to have to reinstall if there is another solution.
Regards,
Doug
Pauly
Printrade.com.au
I "repaired" it, but still the same. I'm getting a message saying "unable to create start file 'C:\program files\onyx\thrive 12\input\arizona\info
I realised there was no "info" folder. Made one and problem solved.
Thanks guys.
J_Print
Thanks guys.
I started having this exact problem yesterday. Could you elaborate on your "info folder" solution for me? I'm a bit of a dullard when it comes to Onyx.
Pauly
Printrade.com.au
If you're having the exact same problem.
"C:\program files\onyx\thrive 12\input\arizona\info" doesn't exsist.
"C:\program files\onyx\thrive 12\input\arizona" does.
Go to C:\program files\onyx\thrive 12\input\arizona and create a folder called "info" and that's it. that was my issue.
