filler sensor location on my roland truvis sg300
signguy74
I have the new sensor and a service manual but still having trouble on pin pointing its location.
Any help would be great
damonCA21
Have you looked at the exploded diagrams to see if you can find it on there? If not look where the wiring to the sensor comes from ( normally the servo board ) and then follow this to find out where the sensor is. I'm not familiar with the truvis, but it is most likely around the print dock area
James Gallant
Graphic Designer
Which filler sensor is it that you need to replace? I just had to replace a couple last week, one on the magenta and then the cleaning tray.
cornholio
The filler sensors are located in front of the printheads on the carriage. Very easy to replace.
  • Agree
Reactions: 1 user
