Firmware Updating (UCJV300/UJF3042-6042 MKII)
Smoke_Jaguar
Not really seen any good guides for firmware updates on these printers. Every printer I use gives me a message of "Your product has the special version of firmware or It is a product that cannot be updated by this application.", even when in service mode. I can connect to the boards with jumpers and all that stuff and flash them in the much more annoying way, but I imagine there is a simple way to bypass this. The few Mimaki vendors I buy parts from on a regular basis essentially tell me to f-off and go to the seller I bought the new printer from (I almost always buy used, way better deal) when I ask if this is even a service they offer. Is this just related to a value set in the firmware, maybe one in the #Adjust menu? I figure it's little more than a firmware flag preventing the updater doing its work.
Are you trying to update the firmware with the Mimaki Firmware Update tool or Rasterlink/User Software? The end user firmware updaters rarely work and that's usually the message you get. Also, some Mimaki dealers aren't servicing dealers so they don't have access to the proper files etc.
simplesignmanII
simplesignmanII
Smoke
We do similar to you in Dundee Uk. Recently bought a second hand UJF-3042HG which was working after a fashion for a few days before it started initialising Z,X and Y then X hit the back of the machine with X 403. Tried many sources but no solution so far. Is this a problem you have experienced ?.
Smoke_Jaguar
I don't work on the first generation UJF line much, most are nightmares at this point with the age of their components.
dudeinthemoon
These machines are old but were much more reliable than mkII.
X 403 is X-motor overcurrent, have you checked the limit sensor? Most likely it doesn't see something or not work at all. Screenshot 2026-04-17 132037.png
