Need Help First cut incomplete on all jobs, Roland xr-640
pipou31
Hello,
after reading on this site for quite a bit, for the first i find myself in a situation that i cant find a solution on here.
I work with a roland xr-640 and so far it has been a great machine.
Recently, i started having problems on the first 20mm or every job cut. it's just missing. i can cut 1200 characters of 2mm each without any issue, great precision, great performance either in direct cut or with the printmarks. But the first 20mm of each job will just not be cut. Ever.
I cleaned the encoder, checked my print/cut align, checked my blade, bladeholder... i just dont know. The printer is in service since 2019 iirc, and i have been working in this company for 2 years, the problem appeared like 2 weeks-ago.
Sorry for my broken english, thanks to everyone taking on their time to read and help.
Philw
I had a similar problem with one of my two VS-300i's but more like 10mm. I changed to a new blade, changed to a new blade holder, swapped blade and blade holders between the two VS-300i's but the problem was persistent staying with the printer.
The cutter strip looked fine and I tried bumping the blade offset up which seemed to reduce the issue but not eliminate it. In the end to keep the printer going I took the starting corner of each die line and put it on top of the complete cutting line, so a full cut plus about 20mm of a second. That sorted the problem but some months later it seemed to resolve somewhat on it's own and while the initial cutting pressure is sometimes close to failing to cut through the facestock it's running pretty much ok.
All I could think of was the solenoid but I wasn't going to pay to replace it.
cornholio
Check the upper limitation bumper of the toolhead. There is a small rubber pad. Add a drop of oil there and you should be ok.
animatorali6
That sounds incredibly frustrating, especially when the machine has been performing reliably for so long. Issues that only affect the first 20mm of a cut can sometimes be linked to initial feed calibration, pinch roller pressure, or even a slight delay in the cutting command response especially after long-term use. Since you’ve already checked the usual suspects, it might be worth having a technician run a full diagnostic or firmware check to rule out sensor lag or mechanical wear.
Also, situations like this really highlight how valuable skilled, experienced technicians are in production environments. If your company ever needs reliable professionals for equipment maintenance or technical roles, this SAAS recruiting agency specializes in connecting businesses with the right talent.
